sanding back external facing wood of french doors. I have do e a first pass of P80 using an orbital sander. Do i continue with P80 to be ready to varnish or should i risk P40?
Hi @mccark185,
I'd continue with the 80-grit sandpaper for now. I wouldn't recommend dropping down to 40-grit unless absolutely necessary, as it is quite aggressive and can quickly remove more timber than intended. It will also leave deeper scratches that require considerably more sanding to remove afterwards.
If you don't already have a random orbital sander, I'd consider getting one as they will help considerably with this process.
Once you've removed the coating, you can progressively work through finer grits to bring the timber up to a quality finish. I'd move from 80-grit to 120-grit, then 180-grit and finally 240-grit. Each successive grit will remove the scratches left by the previous one and progressively smooth the surface in preparation for your new finish.
Make sure you thoroughly remove the sanding dust between each grit, so it doesn't interfere with the next stage of sanding or the varnish.
thanks Jacob. Thinking of taking door off to speed up sanding and varnishing; one at a time. However i see there is some form of cushioning strip over the hinge. Are these required and are they easy to buy and replace?
Hello @mccark185
It appears that the former owner used weather stripping to prevent cold air from entering the house. Yes, they can be replaced with weather seals from Moroday. They come in a wide variety of styles but if you wish to use the same profile, please make sure to keep a sample of the old seals so you can compare it to the ones at the store.
Wood fill before varnishing? Is it required. Not looking for perfection, just better.
I wouldn't call it a requirement, but it is certainly something you could do if you'd like.
Personally, I wouldn't, because I think the cracks and slight weathering give the door character, but if you were to leave them, you would want to ensure you are getting varnish inside all of the cracks.
If you did want to fill the cracks, you would have to use an exterior grade timber filler such as this https://www.bunnings.com.au/polyfilla-450g-exterior-timber-filler_p1210571 which can be stained, clear coated or painted depending on what you're hoping to use. In saying this, if you were to use a clear coat or stain, I'd give it a test in an inconspicuous area first as you may find it stands out more than you would like. Best to test and see before you fully commit to it.
Let me know if you have
thanks Jacob, happy to go with the distressed look and thanks for the tip to get in there with the varnish 😊
