Hi everyone
I’d appreciate some advice on finishing the edges of our deck before we landscape the surrounding yard.
We’re in Canberra region with heavy clay soil. The deck sits quite low, with the ground underneath excavated below some of the surrounding yard level (there's a slight gradient towards the house). There’s currently a messy narrow trench/gap between the timber fascia and the adjacent soil. The attached photos show some of the construction and the current edges.
I'm now learning how low decks can present challenges with drainage, ventilation etc. And in hindsight, a paved patio might have been a simpler option, or perhaps a properly graded and drained concrete slab beneath the deck. However, the deck is now built, so I’m looking for a practical way to manage the edges and minimise those risks.
Ideally, we’d like the finished lawn to be roughly level with the deck, ideally with as narrow a gap as possible (ideally flush transition deck to lawn but I suspect that's asking for trouble) so potentially with a lower garden bed or gravel strip between them? My main concern is how to retain the surrounding soil, and encourage airflow and drainage below the deck as much as possible beneath the deck.
What would you recommend for the edge detail?
How wide and deep should the gap between that edging and the deck be?
Would you leave that strip open, fill it partly with drainage gravel, or do something else?
How could we make the transition from deck to lawn tidy and easy to cross while preserving ventilation?
Would extra drainage along this edge be worthwhile, and how should it work with the edging?
Thanks!
