The corner of the garden was bare after the overflowing gutter eroded the soil and the grass died. It was dust for years! We protected under the gutters with pavers and pebbles. and that protects the new turf. Now its like a little haven.
Brighton
Masonry 400 x 200 x 40mm Charcoal Mypave 424 Paver – front and rear edges 14
Brighton Masonry 400 x 400 x 40mm Charcoal Mypave 444 Paver – centre line 6
Brighton Masonry 200 x 100 x 40mm Charcoal Mypave 214 Paver - corners 3
Brighton Masonry 200 x 200 x 40mm Sand Mypave 224 Paver – one corner 1
Brighton Masonry 400 x 200 x 40mm Sand Mypave 424 Paver (surrounding centre pavers) 48
Brighton Masonry 295 x 180 x 100mm Charcoal Eziwall Block (large inner bend) 6
Brighton Masonry 200 x 130 x 100mm Charcoal Eziwall Lite Block (long outer edge) 58
Tuscan Path 20-25mm 20kg Snow White Quartz pebbles 3bags
Rounded dark grey volcanic pebbles (not form Bunnings) ~7bags
Turf (not from Bunnings) 10m2
Manutec Garden Care Products Soil pH Test Kit x 1
Bag of coarse sand
Several bags of mulch that went round the edge
Shovel
Trowel
Rake
Hose
Garden Gloves
Levelled the dusty area skimming with the shovel and raking, wetting the ground to keep dust to a minimum and spread a layer of sand across the now wet ground.
- Step 2:
Pavers were then progressively laid in the pattern we desired, each of the large pavers in a central line down the walk way, and organised smaller pavers round the edges, tamping them in to the sand. Between pavers we sprinkled a mix of the different coloured pebbles.
- Step 3:
We visited Bunnings A LOT!
- Step 4:
We then prepared the area for the turf. We lifted the original pavers and reorganised them and softened the dirt, wetting it, and mixing in several bags of general garden soil. We did a pH test and added a tiny bit of lime to get the pH right for the grass. We wet it more and raked it flat.
- Step 5:
When the turf arrived we laid it straight onto the prepared soil cutting it round the curves. Finally we put a layer of charcoal Eziwall blocks around the edge between the grass and the flower bed. And watered the grass in for a few weeks.
