Attached is a photo showing:
A new deck made out of merabu with an old deck. This is 2 weeks old.
My question: How do I paint or oil the new deck so it is close to the colour of the old deck ?
Hello @GaryArmadale
Thanks for sharing your question about your deck. Your deck has been freshly installed, and I suggest letting it season for around six to eight weeks or longer depending on the weather. Seasoning means that you that you allow newly installed timber decking to weather and stabilise naturally before applying oil, stain or any another protective coating. Fresh decking timber can contain natural oils, tannins and moisture that may prevent a coating from penetrating properly. Leaving the deck exposed to the weather for a period of time allows these to reduce and come out of the timber to settle. Once seasoned, the deck is cleaned with a suitable deck cleaner and then coated.
Matching the exact stain of your old decking is not possible as it has been exposed to the elements. The current colour your deck has is the product of the old stain, exposure to the elements and dead timber fibres that are on the surface. The best you can possibly do is to get a close match or be just as dark. But being a newly stained deck it will stand out even if you get very close to the colour you are after.
Because your deck is currently wet, I'm a bit hesitant to recommend any stain colour. But an example of a dark stain is https://www.bunnings.com.au/feast-watson-4l-black-japan-decking-stain_p1540453 . However, I strongly suggest visiting your local store and having a look at the stain sample board in the paint department so you can see the actual finish of the oil on timber.
Thanks Eric for your reply.
Just wondering if would be better to repair the old deck and then see if I can use the same paint or stain on the new and old deck. Use a deck repairer to do this.
If the old deck is still in good condition and none of the decking panels have rotted, it might be possible to sand the surface back to timber. However, it is difficult to tell what kind of timber decking was used for the old deck. It's clear that Merbau was used for the new deck and if the old deck is made of something else such as pine or cedar getting a similar colour finish is not likely.
For example, if you used a natural oil finish on the Merbau it will come out differently (possibly darker) as the old deck will react differently to the natural oil (could look like a dark wet finish). Even if you used a Merbau stain, you would get a darker finish to the new section as it is enhanced by the merbau timber while the old section will have a shade of Merbau but not as strong as the new deck.
