Moved into a new place and the wardrobe sliding doors are partially stuck. I tried pulling the door and this whole piece popped out. The wheel is not rotating at all. Can this be replaced?
Hello @weirdwhiskers
Thank you for sharing your question about your wardrobe doors. I suspect that the holding or mounting screw of the roller assembly has fallen out or dislodged itself. In order for our members to get a better idea of the wardrobe doors condition, would it possible for you to post a photo of the bottom of the wardrobe door, the front section showing the rail and an overall photo of the wardrobe door itself? Please do not take pictures that are extremely close up as we need to see the assembly and how the wheel fits into the frame.
Once we see the photos of your wardrobe frame we'll be able to offer possible solutions.
It is a bit difficult to take photos as I live alone and have no one to help remove the door at the moment. Hope these are sufficient?
Thank you for sharing those photos of your wardrobe door. I've placed images below with white and yellow arrows indicating parts that interact together with your roller. From what I am seeing, it appears that the roller has slipped out of its housing and the screw that is holding it in place has come loose.
My first suggestion is to fix the distorted steel housing with a pair of https://www.bunnings.com.au/craftright-200mm-combination-pliers_p0916080 . I recommend slowly bending the bent section back and try to make it as straight as possible. This should turn the clip that holds the roller assembly inwards. I've placed three images below to give you an idea of how the roller is attached to the main body.
The roller set slides into the main body and the screw at the top adjusts the height. However, if the screw that controls the height of the roller is broken or the top of the roller is damaged then the whole set will need to be replaced. The first image shows you what its suppose to look like when assembled. The second image shows you how the screw attaches to the roller. The last two pictures show you how they are supposed to join together.
I can give it a go, however I think one of the reason it popped out was because the wheel itself isn't turning. It is completely stuck.
Hi @weirdwhiskers,
If the wheel is completely seized, your first option would be to see whether you can get it spinning again. Sometimes hair and debris become wrapped around the axle, preventing the wheel from turning. You might be able to carefully cut away any tangled material and free it up.
If that doesn't work, you'll likely need to replace the roller mechanism. From the images, it appears to be a proprietary system manufactured by a specific company. There looks to be some branding on the mechanism, which might help you track down a compatible replacement.
Alternatively, you could enlist a professional to replace the existing roller system with something more readily available off the shelf. However, the bent roller cartridge housing would also need to be replaced with a compatible mounting system.
This would really require someone familiar with installing wardrobe sliding door systems, as the replacement components would need to suit your particular door.
I was looking through the Bunnings spare parts for rollers and happen to come upon the https://www.bunnings.com.au/rolltrak-adjustable-steel-carriage-and-acetal-roller_p3985411 . My best advice would be to match it against your existing roller and see if it is compatible with your door.
I printed the scale diagram and it looks like it'd fit!
Thanks for your assistance Eric :)
