Can I fix these cracks on tiles without replacing them and if so then with what materia? And fron steel bracket is also loose how to fix this as well
Hello @Docnhabib
Can you please tell us where exactly is this tile located? Can you please provide a wider picture so that we can see where this tile is positioned? In regard to the metal tile finish, if it is loose, odds are it has come off its adhesive mounting. It will need to be glued back into place, but it is best to fix the broken tile first before gluing the metal edging in place.
Attached are photos from laundary and toiletl
Thank you very much for sharing those extra photos of your tiled floor. It appears that there was not enough adhesive placed under the tile at the time that it was installed. You can clearly see that the tile broke when someone walked over on the corner and it has gone down at an angle. If something was dropped on it it would have had a different type of damage. But when tiles have gaps or are unsupported at the bottom they break in this manner.
I don't recommend putting a patch on this tile as it can no longer be repaired or disguised. I suggest removing the tile and totally replacing it. However, I suggest finding a similar sized tile first before you attempt to remove it. If you've never done any tiling, I suggest engaging the services of a professional tiler. The same issue is present in your laundry flooring. I recommend doing a proper repair as a patch or cover is no longer applicable.
I also recommend looking at these guides - How To Lay Floor Tiles and How To Grout Tiles.
Please remember to wear personal protection such as gloves, goggles and a mask.
