Hello, I'm looking at different options to connect my 100 X 50 downpipe directly down into the stormwater. Currently there is gap and it splashes back and can't drain away fast enough causing minor flooding which then Leaks into the garage wall.
I'm thinking of a few things. Firstly a Holman 100 x 50 x 90mm PVC Stormwater Downpipe Adaptor With Inspection Flap, then I need to connect a 90mm PVC pipe or flexible hose as the downpipe doesn't drop down directly into the opening (unfortunately). I'll then use crommelin natural brick Sealer on the bricks reduce seaping and a caulk along the paving brick join. Then some bitumen under ground paint along the garden bricks. What are your thoughts? Thanks!!
