Hi everyone
I have a toilet that only stops running water into the bowl when I turn the cistern tap off.
I tried tightening the screw for the lever and it still runs.
Any ideas?
Hello @Shaun12
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your toilet cistern.
Please note that any plumbing work needs to be carried out by a licensed professional for safety and compliance.
I'm sorry to hear your cistern has sprung a leak. Turning off the cistern tap is one of the basic trouble shooting steps you can take. Turning off the cistern tap isolates and reduces the likely point of failure. Now that the cistern tap is off, you can listen for any leaks that may be happening in your cistern. When water continues to enter the cistern, it has an overflow safety feature that lets the water out into the pan. Depending on the severity of the leak this can sound like dripping or a continuous sound of very light flushing.
But if the cistern tap is off and you don't hear any type of leak, this means that the flushing washer is intact and is not the cause of the leak. But when the cistern tap is turned back on and the leak returns you can then conclude that the inlet valve is at fault. The inlet valves job is to halt the flow of water once it reaches the correct level in your cistern tank. I recommend replacing the washer in your inlet valve first and see if that fixes the issue.
However, if this fails to correct the issue, odds are the inlet valve itself is faulty and will need to be totally replaced. Please note that any movement or rearrangement of pipework is considered regulated plumbing work. This includes the removal and re-installation of your inlet valve. It must be carried out by a licensed plumber.
