I am wanting to build a balustrade like the above photo. My exisiting timber balustrade has lattice in the centre, so I can use the existing horizontal top beam and the vertical beams (marked in red as an example). I will need to install a bottom beam in each section, a beam below the top rail and the vertical slats. Do you have recommendations of the timber I should buy for these sections? I will also be painting it white. And recommended screws and drill assists for going in at a 45 degree angle.
