I was pretty much ready to buy the RYOBI R36LMW34 36V HP 46cm lawn mower, but decided to double-check whether it can be used without the grass catcher.
Usually a mower either comes with a mulching plug, or the rear flap is designed so you can mow with the catcher removed and the flap closed.
I contacted RYOBI support and they told me there is currently no compatible mulching plug for this model, and that you shouldn’t use it with the catcher removed and the rear door closed because grass can build up in the chute and potentially restrict the blade.
So, based on RYOBI’s reply, it sounds like the mower is basically unusable without the grass catcher fitted. That seems like a pretty ridiculous limitation for a $499 mower.
Has anyone here actually used the R36LMW34 without the catcher, or knows if there’s another approved way to do it?
