I can’t work out why no water is coming out of my spray gun - it looks to be securely connected.
The spray gun won’t push in any further
Hello @Joyous
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your garden hose.
I'm sorry to hear that you are having trouble with your garden hose and spray gun. If you look closely at the photo you posted, you'll see that one of the hose connectors has a white plastic protrusion with a rubber O ring on it (see photo at the bottom). That connector is supposed to be connected to the hose spray gun end not the garden tap. My best suggestion is to simply swap the ends of your garden hose there is no need to take them apart.
The purpose of the stop valve is to cut off the water flow when any hose end attachment is removed. If it is facing in the wrong direction the stop valve will activate and prevent water from coming out.
thanks Eric!!
This solved my problem 👍 love ya work 😊
