Will any of these be suitable for lining corner of ceiling and walls of multipurpose garage instead of normal cornice. Thanks
QuickBoard 30 x 30mm 2.7m Arctic White PVC Composite Equal Angle Trim - Bunnings Australia
PermaTimber 19 x 19mm 2.7m Antique White PVC Tri Quad - Bunnings Australia
Hi @ELI5,
Yes, both the QuickBoard 30 x 30mm PVC Composite Equal Angle Trim and the PermaTimber 19 x 19mm PVC Tri Quad would be suitable options for finishing the junction between your garage walls and ceiling.
For installation, I'd recommend using a construction adhesive that is compatible with PVC and the surfaces you're attaching it to. Apply a bead of adhesive along the back of the trim, press it firmly into position and use painter's tape to hold it in place while the adhesive cures. You can cut the trim to length and mitre the corners using a fine-toothed saw and mitre box.
Just make sure the surfaces are clean, dry and free from dust before applying the adhesive.
Let me know if you have any questions.
