Looking for solution to repair letter box door that has come away from the surrounds. The entire door /plate can be removed. To me it looks like the concrete has been removed but no confirmation. This is in a complex / units so it needs to be repaired, I will not be allowed to change the letter box. How can this door be re attached? All suggestions welcome and thanks in advance.
Hi @ShellG,
What you have is referred to as a brick in letterbox, and it is very similar to this https://www.bunnings.com.au/sandleford-160-x-235mm-aluminium-brick-in-letterbox-set_p2940313 . They are set in place using standard mortar. It looks like the mortar surrounding your letterbox has deteriorated over time, but fortunately, this should be a relatively straightforward repair.
I'd suggest starting by removing all the loose and crumbling mortar using a cold chisel and hammer. Carefully chip away the degraded material until you reach solid mortar, taking care not to damage the surrounding bricks or letterbox. You can then use a stiff brush to remove any remaining dust and debris.
Once the area is clean, lightly dampen the surrounding masonry before applying some fresh mortar mix to all sides of the opening and then pressing the letterbox plate into place. Use a pointing trowel to push the mortar firmly into the gaps, ensuring they're completely filled. Smooth the surface to match the existing mortar joints and clean away any excess from the bricks before it hardens.
It would also be worth using some painter's tape to help hold the letterbox in position while the mortar cures. You could run a few strips across the face of the letterbox and secure them to the surrounding bricks to help prevent any movement while the mortar sets.
Allow the mortar to cure according to the manufacturer's instructions, and avoid disturbing the letterbox during this time.
Make sure to wear gloves, safety glasses and a P2 dust mask when removing the old mortar.
You might also like to have a look at our guide on How to mix mortar for some additional guidance.
Hi Jacob, thank you so much for the prompt and detailed reply! I will try the method outlined and get my letter box back! Thanks Jacob, Regards, Shelley
Keep us in the loop @ShellG. We're happy to help further if it is required. I can't wait to see the finished product.
