Replacing expansion joint seals between an exterior brick wall and tiled patio.
After removing the old sealant and backer rod, I’ve found that some sections have a void underneath of up to around 30 mm.
The previous repair appears to have used backer rod and flexible expansion-joint sealant, with some type of mortar/cement over parts of it.
What’s the best way to deal wtih the deeper void before installing new backer rod and sealant?
