I plan to attach Ekodeck 219 x 26mm 3.6m Hazelwood Batten Screen Castellated Panel in front of my Colourbond fence. What is the best way to attach it to the fence, and is there a Hazelwood topper that I can put along the top of it?
Hi @Lennock,
Unfortunately, Colorbond fences are not designed to support the additional weight of products such as Ekodeck batten screening. While the fence itself might seem quite sturdy, its posts and footings are not designed to support the significant additional weight that this would create. Because of this, I wouldn't recommend attaching the Ekodeck panels directly to your existing Colorbond fence, regardless of the screws used.
The best option would be to construct a separate frame that stands independently of the existing fence. This would involve installing posts into suitable concrete footings, then attaching horizontal rails between them to support the Ekodeck panels. The framing would need to be designed to accommodate the weight of the screening and the additional wind loads.
You might like to have a look at our previous discussion, How to install Ekodeck castellated panels onto retaining wall, where @Neil1984 has constructed an independent frame to support his castellated panels.
Your frame doesn't necessarily need to be exactly the same as Neil1984's, but it does need to be sturdy enough to support the panels. It could be made from steel like there's was, or it could be made using timber posts and rails.
Check out the following video for another example of framing that you could use, as well as some information on the installation process for the panels.
To finish the top, Ekodeck recommend using modified https://www.bunnings.com.au/ekodeck-60-x-27mm-2-7m-j-channel-hazelwood-shiplap-cladding_p0617435 which is colour matched to your panels.
