My husband and I were sick of spending every weekend tirelessly mowing the backyard. Being on a slight slope (like most of the Illawarra) we wanted to utilise this to create a rambling native garden with minimal maintenance. Sourcing only the best of native plants and gathering as much as we could from Facebook marketplace we created a garden that can be enjoyed through all seasons and the hardest part is choosing what flowers to use in our weekly flower arrangement. 🌺💐
- Pillar weed matting (https://www.bunnings.com.au/pillar-1-8-x-25m-black-landscapers-weedmat_p0542243)
- Jack mat pins (https://www.bunnings.com.au/jack-weed-mat-pins-50-pack_p0333290)
- Jack oxysheild garden rings and edging (https://www.bunnings.com.au/jack-900mm-oxyshield-podium-landscape-ring_p3321632)
- Travertine pavers ( https://www.bunnings.com.au/cliftonvale-610-x-406-x-30mm-travertine-natural-stone-paver_p0131434)
- Sand and cement (https://www.bunnings.com.au/australian-builders-20kg-sand-and-cement-mix-bag_p0760612)
- Bastion river sand (https://www.bunnings.com.au/bastion-20kg-river-sand_p0760538)
- Lots of plants, focus was on kangaroo paws, grevilleas, native grasses, banksias, wattle, ivory curl tree and some olive trees.
- Mixture of garden compost, soil and manure I like to use the richgro mushroom compost as a base with the garden basics soil and fine farms poultry manure. My go to mixture is 3:3:1 (soil, compost, manure) for a rich nutrient dense base for getting the plants started.
- Cyclone steel trowel (https://www.bunnings.com.au/cyclone-stainless-steel-garden-trowel_p3360998)
- Cycle shovel (https://www.bunnings.com.au/cyclone-square-mouth-deep-hole-shovel_p0013516)
- Trojan mattock (https://www.bunnings.com.au/trojan-2kg-mattock-with-cutter-end-timber-handle_p0684996)
- Ryobi reciprictaing saw (https://www.bunnings.com.au/ryobi-18v-one-compact-reciprocating-saw-tool-only_p0991763)
- Buckets for mixing sand and cement
- Saxon garden roller (https://www.bunnings.com.au/saxon-30l-water-filled-poly-garden-roller_p0675650)
Start by spending time analysing your garden. You don't want to spend all that money on plants and in the winter they die off due to increased moisture and not enough sun. We spend a year keeping track through all seasons of where water collected, sun was too hot in the summer and what needed protection. Throughout the seasons we researched what plants would work in each spot and what wouldn't etc. Don't skip the planning.
- Step 2:
Once you have marked out your site and have your design the fun begins. We started with the hard scaping and garden edging first. This allowed us to backfill with the nutrient rich soil mixture and build up the garden beds. There will be a few sweaty days here adding edging, posts and minor site excavation to create more level sections. A handy hint to remove root balls and shrubs is the Ryobi reciprocating saw which cuts through roots like butter and can be dug out.
- Step 3:
Once the mess has been cleared the fun begins. There are a number of ways to lay weed matting. I chose to put in my plants in the ground first, layer with cardboard around the plants, wet that down and add pea straw mulch. This extra step with the weed matting on top will dramatically reduce weeds coming through that first year.
- Step 4:
We chose only one small grass section to have something soft to walk on and the children to play. To continue with the no mow theme we chose the top of the line Sir Grange Zoysia as it was only a small strip. We followed the laying tips from turfco which is on a bed of river sand and some compost. It required a bit of watering but it was continued to thrive, soft under foot and requires a run with our push mower every few months.
- Step 5:
To offset all of the green that would soon be thriving int he garden we chose to intertwine walkways of pink granite. One it looks fantastic and two the gentle crunch under foot when you meander around the garden with your morning coffee is very relaxing. Granite can be very costly so we used a bed of compacted sand underneath and laid the granite on top to reduce costs and make it more compact. We hired a compactor for the granite but we found it was too soft to we used the Saxon garden roller to compact the rock and tidy up when needed.
- Step 6:
Next is to mulch, mulch and then mulch. We used a cheaper mulch alternative from our local landscaping company which is mulched leaf and bark. It was only $35 per cubic tonne and we needed a lot of it. It also breaks down nicely over time and adds vital nutrients into the soil.
- Step 7:
To add to the natural native look I also sourced large garden rocks from Facebook market place. FOR FREE. Although I personally loaded and unloaded several tonne of rock over a few days it really adds depth and interest to the final garden look.
- Step 8:
For the main walking thoroughfare I added travertine pavers and cobblestones I sourced on marketplace to reduce stones being walked through the house and onto the grass. This also covered an old ugly concrete path to the clothes line so we had a solid foundation to sand and cement over.
- Step 9:
Using the amazing oxysheild garden rings from Bunnings we added some feature plants to utilise height and visual interest in the garden. Lining the fence are some olive trees with native violets to create that sense of movement in the garden.
- Step 10:
You will need to water your garden in well for the first year to help everything become established. Over the summer months the garden was watered twice a week and then pulling back over winter as we get a lot of built up moisture int he garden. The second year of growth is pictured here and apart from some small flowering gums everything
is well established and at full height. It is a haven for bees, butterflies and creates a sense of calm as you walk through to each garden area.
