hi everyone just wondering if anyone has any tips of what we can do to upgrade this stone wall? We were hoping do do a concrete render or similar ?
Hello @emmawigg
Thank you for sharing your question about your stone wall tender. Before you render the front of the wall, I suggest digging behind the wall first. It's important to find out if the wall was properly sealed with a water proofing membrane. If there is no sealer behind the stone wall hydrostatic pressure from the other side will push and damage the render you've just put in front of the wall. Even painting the surface is not recommended as the same thing will happen to it.
What are some of your options? You could build a timber frame over the wall and cover it with cement cladding and render over that material. The timber framing will serve as a gap between the cladding and the stone wall preventing water or moisture from reaching it.
Another option is to cover it with timber sleepers. Again, you'll need to install a timber frame to hold the sleepers in place without touching the wall. The last option is to dig behind the wall all the way down and apply a sealer such as https://www.bunnings.com.au/gripset-betta-1l-waterproofing-membrane-bitumen-rubber_p0960165 . Once the sealer is applied, I would still recommend letting the stone wall dry off to reduce any trapped moisture inside before you try to render the surface.
I also suggest having a look at this discussion - How to use blueboard for rendered retaining wall? by @lyndal1.
