I've dug up this Ginger plant and want to replace it with Grevillea.
Underneath the deck is now a gap I want to cover with plyboard. Length 1840mm length x 400 high mm x 6mm thick. I will leave a gap of about 100mm above the soil so the panel does not touch the soil.
(Disclosure - I used AI for a lot of what follows - I hope you don't mind.)
It recommended I use (links included) :-
Plywood: 2440 x 1220 x 6mm Marine AA Grade Hardwood Plywood.
Batten: Porta 42 x 18mm 2.7m H3 Primed FJ Pine Dressed Board. To attach at the bottom back of the panel to stop it warping
Glue: Selleys 350g Liquid Nails Exterior. To glue the Batten to the back of the panel.
Nails: Paslode 30 x 2.0mm Galvanised Flat Head Nails, 500g. Nail to the top beam, the posts and also the batten through the 6mm board and 18mm batten.
Need to prime and paint it. It suggested.
Primer and sealer: Dulux 1Step Prep Primer, Sealer & Undercoat.
I've also got some left over Dulux Weathershield for the top coat/colour.
Question 1)
Does the above sound reasonable? Is it overkill? Have I missed anything?
Question 2)
As to the actual planting. It does have brick edging on left and front but not near the step (where the broom is). Also the soil spills over the front bricks to the gravel path - so I am thinking of using this steel edging inside the brick on the 3 sides - left, front and right (near the broom to protect the wooden steps). The bed slopes up a bit under the deck so I don't think I need it on the back (under the deck). Choice of :-
or Jack 2440 x 100
or this one Roll
Question 3) How can I cut these to size?
Question 4) I probably need to top up the garden bed with some potting compost. Should I combine it with soil improver or just use potting compost? (I'm not sure what's the different between the two).
Ok - hope the above makes sense,
Many Thanks
Tim
