The size 300x17x13mm I bought. But 13mm is too wide. The brown one I have is about 8mm. Some of the brown runners are broken. Can you help. Please and Thanks
Just to add one more photo to the above. It to show what i mean if I install it. The drawers will not go in
Hi @melissa2024,
Can you confirm whether your drawers have a groove routed into the sides for the runners to sit in? If so, how deep and how wide is it?
Looking at the dimensions, I think the best option would be to return the runners you've purchased and use these Taskmaster 295mm White Plastic Drawer Runners instead. These are designed to be attached directly to the drawer rather than requiring a routed groove. They're only 6.5mm wide, so they should work with the space you have available.
You would just need to mark out and drill 7mm holes in the sides of the cabinet to accommodate the locating pins on the runners, allowing them to be pushed into place and secured.
Hi, the groove on the drawers are 118 x 8mm. I got the taskmaster 295mm runner too. So trying to figure out how to fix it . Thanks
Sorry forgot the photoabove
Thanks
As per the instructions, you need to mark the location of the runner on the inside wall of the cabinet carcass, marking the location of the tabs on the runners.
You can then drill holes in the cabinet carcass for the tabs using a 7mm drill bit such as this https://www.bunnings.com.au/kango-7mm-hss-drill-bit_p0354531 . You can mark the depth of the tabs on the drill bit using some painter's tape to ensure you don't drill straight through the carcass.
You can then tap the runner into the holes to fix it in place.
Let me know how you go and if you have any further questions, please don't hesitate to ask.
