I guess this is probably more a personal preference.
When you are building a deck on a North-South slope, and you install fascia boards on the North-South side, would you stagger or "step down" the fascia boards, or would you cut the boards to somewhat "hug" the contour?
It's a composite deck (something similar to Ekodeck) on an aluminium subframe, on rocky ground, so air circulation is not an issue. The highest corner of the deck is about 750mm off the ground.
