I am renovating a small house. It has corrugated iron roof. I have recently removed ceiling as i wish to add interior lining boards throughout (after insulation) across walls and roof. After removing the ceiling i can see quite a bit of damage to the sarking. I would prefer to hold off on replacing (when i can eventually get to the roof) but want to go ahead and install insulation and start interior walls. Is it worth repairing some damage from the inside - and if so how can this be done? Thanks
Hi @KPD,
Whether you need to repair the sarking now largely depends on whether the causes of the damage have been rectified.
Some areas appear to have been chewed by rodents, while others look to have suffered water damage. Has the roof leak responsible for the water damage been repaired?
If the water ingress has been resolved and the rodents are no longer present, you could potentially leave the damaged sarking until you're ready to replace it.
The difficulty with repairing it from underneath is that sarking should ideally form a continuous, correctly overlapped layer beneath the roofing. You could use suitable sarking tape and additional sections of sarking to temporarily cover the damaged areas, but this shouldn't be considered a permanent repair.
My main concern would be ensuring there's no ongoing water ingress before installing insulation and internal linings, as you wouldn't want to conceal a problem that could cause further damage.
thanks very much @MitchellMc - is there a way of determining whether the leaking has been repaired ?
Hello @KPD
You can do a water test with your garden hose or wait for the next rain shower to pass your area. Once the water hits your roof you'll need to look under your roof frame to see if any of that water passes through the sarking or is bridging on the timber frame. If it is, it's fair to say that the roof is still damaged and it will need to be either repaired or replaced.
thanks @EricL - also is there a rodent protection barrier i could add from the inside of the ceiling or is this best from outside ?
Unfortunately, I'm not aware of a specific rodent barrier product that would be suitable or something that could be installed in the same vein as sarking to prevent rodents from accessing the roof space.
I'd recommend speaking with a professional pest control specialist, as they'll be able to assess how the rodents are accessing your roof space and recommend suitable measures to prevent them from returning. The most effective approach is generally to identify and seal potential entry points from the outside using products like this https://www.bunnings.com.au/envirosafe-9m-rodent-barrier-stainless-steel-mesh_p1158242? .
You might find our guides on How to get rid of rats and mice and How to pest-proof your home helpful. They cover some general steps you can take to discourage rodents from entering your home, including removing food sources and addressing potential access points.
