Hello, just wondering if something like no more gaps would be enough for this gap or it will require something more? Thanks :)
Hi @zigger777,
You could certainly use https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-fast-dry-gap-filler_p1230089 to fill the smaller cracks, but the larger opening at the corner suggests the cornice may have separated from the wall or ceiling.
Before filling it, I'd recommend gently checking whether the cornice is loose or moves when pressed. If it's secure, you could fill the larger gap with https://www.bunnings.com.au/gyprock-csr-2-5kg-cornice-cement-2-5kg_p0730786 , allow it to dry, then finish with No More Gaps for a neat joint before painting.
If the cornice is loose, it would be best to resecure it with cornice cement and potentially some screws before attempting any cosmetic repairs. Here's a helpful guide: How to repair a cracked cornice.
Thanks Mitchell,
I got up there and checked, thankfully its hard with no movement when pressed. Cheers for the info i will head into Bunnings and get some cornice cement and no more gaps! :)
