I’ve bought some Rapid Fence posts and plan on fixing some solar lights to them.
Best ideas to secure it up?
Hello @geoffcox
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about fixing festoon lights to rapid fence posts.
For long term fixing, I suggest using https://www.bunnings.com.au/rapidfence-roll-top-wire-mesh-fence-u-clips-and-teck-screws-20-pack_p0287578 in combination with UV stable cable ties such as the https://www.bunnings.com.au/crescent-150-x-3-6mm-black-cable-ties-25-pack_p4431120 . My best advice is to pre-drill the post so that it will not be too difficult to attach the clips to the post.
Please remember to wear personal protection such as gloves and goggles when working on your project.
I also recommend having a look at this guide - How to install outdoor string lighting by @Adam_W.
thank you Eric, given that the post will be cemented in, for a lightweight set of lights is it necessary to run wire then atttach the lights via zip ties or can it be strung up without?
It's better to have a wire so that there will be no stress applied to the electrical wire of the festoon lights. Although it is lightweight, environmental factors such as the sun, wind and rain will apply stress to the unsupported electrical wire. When repeated continuously it will affect the festoon lights assembly. It is better if the festoon light assembly is fully supported.
