Hi.
Does anybody know the best solution to buy/make to clean Lichen and Mould off bricks that won't damage the mortar. Please see attached photo.
Any will will be appreciated.
Cheers
Jeff
Hi Jeff (@JJM1),
I'd recommend starting with https://www.bunnings.com.au/30-seconds-1l-outdoor-cleaner-spray-1l_p4461747 , which is designed to remove mould, mildew and algae from outdoor surfaces, including brickwork. For stubborn lichen, you may need to repeat the treatment, as it can be more difficult to remove than surface mould.
Apply the cleaner according to the manufacturer's instructions, allowing it the recommended dwell time. You can then use a scrubbing brush to remove the growth before rinsing with clean water.
If some of the lichen remains, I'd suggest allowing the bricks to dry before repeating the treatment and giving the affected areas another scrub. Lichen can adhere quite firmly to porous brickwork, so it may take a couple of applications to remove it completely. If you're still having trouble, a pressure washer on a low-pressure setting could be considered, but I'd be very cautious around the mortar joints and avoid this entirely if they're showing signs of deterioration.
Please remember to wear a mask and some chemical resistant gloves while working around mould and chemicals.
Hi Jacob,
Thanks for the above, I'll look into it and see how I go.
Appreciate the response
