Hi all,
I’m moving into my first home soon and after final inspections I found out that the bedroom door is dragging on the floor. I’m not sure if this was due to humidity but it’s definitely been an issue for awhile because the bottom of the door itself is damaged.
Is it advisable to cut off a couple cm off the bottom of the door? Or should I consider changing it altogether?
Thanks in advanced!
