Two tables that join to make an outdoor kitchen area in a courtyard. One to go over the aircon unit where the BBQ will sit with the gas bottle underneath, the other will be used as and extra bench or dining table. The smaller table with lower shelf for plants and decor with baskets underneath for storage.
Black metal legs Slim to fit in tight spot! The top is wide Merbau decking ideal for outside, plus already oiled. Treated pine for frame.
Ozito battery tools. I use three drills,
1 X drill bit, 2 X screws 3 X for counter sink
Sander, Drop saw, clamps, liquid nails,
1: cutting treated for pine for under frame, several strong pieces for strength. Glue and screw.
2: attach metal legs to under side.
3:Cut merbau to length attach to under frame using wood spacer to make evenly apart
4: screw under frame (with legs) to merbau top
5: complete second table to match
6: the same principle applies to the console table. I used mainly off- cuts for the base, and dressed pine for the top, finishing with decking oil ti match tables.
