What Is the best way to repair this joint that has come apart?
Regards
Steve
Hello @SteveC
Thank you for sharing your question about how to repair a crack on your plaster wall. I suggest having a quick look at this discussion - How to fix dent and cracks in plasterboard wall? by @Calixta. I also recommend reading these guides - How To Patch A Plaster Wall and How to choose the right plaster for your repair.
The basic steps are to cut a small "V" channel in the crack using a craft knife and sanding the surface level. You then wipe the sanding residue off with https://www.bunnings.com.au/selleys-sugar-soap-wall-cleaning-wipes-25-pack_p1210330 . Allow the damp surface to dry off and then fill the crack with the appropriate filler. Allow it cure and then sand it level. Wipe the surface one more time before you prime and paint the surface.
