my grass tree is 15 Years old and is beginning to yellow. What should I do please. It has always been so lush and green. I live on Mornington peninsula Victoria.
Welcome to the Bunnings Workshop community @Jujunana. It's wonderful to have you with us and many thanks for your question on grass trees.
Given that your grass tree has been healthy for 15 years and is only now beginning to yellow, I'd suspect something has changed in its growing conditions.
When did you first notice the yellowing, and can you think of anything that might have changed around that time?
There are quite a few possibilities worth considering. For example:
One thing that particularly catches my attention in your photo is what appears to be synthetic turf surrounding the trunk. Could you confirm whether that's artificial grass and, if so, when it was installed?
I can't imagine a grass tree would appreciate having synthetic turf surrounding its base. It can restrict natural water penetration and airflow into the soil, while becoming extremely hot during summer, potentially overheating the soil and damaging the fine roots beneath.
Even if the yellowing only began a year or more after the synthetic turf was installed, I'd consider that a significant warning sign. Root damage and environmental stress can take considerable time to become visible in an established plant.
I wouldn't rush into applying fertiliser or increasing watering until we've established what's causing the decline, as either could make matters worse.
If you could let us know when the yellowing began, whether the synthetic turf was installed recently, and whether anything else has changed around the plant, we should be able to narrow down the likely cause.
Thank you so much Mitchell. Yes it is synthetic grass at the base and was put there earlier this year so yes that could be the problem even though I left a gap around the bottom of the trunk ? Do you think? Also we did also have a lot of rain over the winter months so that could be the cause alongside the fake grass. I will remove the fake grass and let’s hope it improves. As this was a beautiful tree. It did have a flower about two years ago but I read that would distress the plant so cut it out ( that was very difficult and changed the shape of the formation of the grass) Do you think I could put some fine stones around it to make the ground look more aesthetically pleasing. (that’s why I put the fake grass there to keep weeds out) I also did begin to water more as I thought that was why it was stressing due to past month having no rain after the wet winter. Should I therefore take away the fake grass, cut the dead ferns off underneath and not water for a while? Would that be the way to go? I do really appreciate your advice. Many thanks
Hello @Jujunana
I propose removing the artificial grass to allow the soil to breathe and absorb nutrients. At the moment I would hold off putting anything on the soil as it has in a manner of speaking been suppressed. I understand that you want it to look nice, but I suggest using a https://www.bunnings.com.au/trojan-all-steel-spiked-aerator_p0131548 to loosen the soil around the grass tree while trying to avoid its roots. Your objective at the moment is to stabilize and recover the grass trees health. Please keep in mind that overwatering is also bad for the grass tree. I suggest testing the soil around the grass tree and see if it overly damp. Push your finger into the soil around 25mm and if it is soaked, I suggest letting the soil dry out first.
Grass trees are naturally adapted to Australia's hot, dry conditions and can survive extended periods with very little rainfall. Their extensive root systems help them access moisture in the soil, while their tough, narrow leaves reduce water loss. I recommend watering an established grass tree only during prolonged dry periods, generally every two to four weeks if there has been no significant rainfall. They prefer well-drained soil, as excessive moisture can lead to root rot.
thank you Eric. Your knowledge is much appreciated. Judi
