I've got a front door which has a slight lean to it. It causes it to rub against the frame, but even worse it means there are large gaps on the outer top and inner bottom corners. It's particularly apparent at night as you can see the light leaking out of the top corner when you approach the door.
I have tried replacing the hinges and adding longer screws for the hinges to try and pull the top of the door closer to the frame but without success. Hopefully you can see in the photos that the gaps down the sides of the door appear to be relatively uniform, and it is mostly the top where there is a large difference. I also tried using some shims to then readjust the pins on the hinges (even though they were new) but this just damaged the door frame more than anything else.
The door is probably about 25 years old and is quite heavy.
What's the best way to fix the lean/sagging? Do I need to sand/plane down the edges of the door?
Thanks!
P.S. Don't mind the bubble wrap on the handle, that's just there to protect the walls until I can put on the permanent door stop, but I can't do that until I'm sure the height of the door won't change.
