Easy raised garden bed to transform a boring small garden into a lush tropical outlook. The soil here is hard clay and there is no shade to grow plants that would fry in the Queensland sun. The solution is a raised garden bed with tall planting at the rear to create its own shade. I am a single lady in my 60s with no helpers, so anyone could do this.
- Brighton Masonry 295x180x100mm charcoal Eziwall blocks
- Road base (bags)
- Premium garden mix (bulk)
- Scoria or drainage gravel (bags)
- Compost, manure, mulch (bags)
- Tropical plants
- Reticulation basic setup
https://www.bunnings.com.au/search/products?page=1&q=brighton+masonry+295+x+180+x+100mm+charcoal+eziwall+block&sort
- Hand tamper to compress the road base
- Spade, fork to mix in manure etc
- Spirit level
- Kneeling pad (for poor old knees)
- Measuring tape
- String line and metal posts with holes
- Decide how many levels of bricks you are doing. I did 4 rows, including 1 under ground level. This and the dimensions will determine how many Ezi wall bricks you need.
- Dig out any grass and debris. Decide on the shape of the garden bed. I lined up the back and side with the colorbond fence, which means you can measure from that more the string line. Leave a gap big enough so you can walk around and do pruning etc . A curve always looks nice from the front. Use a garden hose to get a natural look. You can mark it out with the special spray paint.
- Step 2:
- Dig out some garden soil a bit wider than the brick.
- Pour out some road base and use the tamp to compress it.
- The first row is the most difficult as you need to line up the top of the brick with the string line and check each brick with the spirit level. Generally you want the decorative side facing the front, but I used a one plain and one decorative to fit the first row better in the ground.
- Just angle the bricks around to fit the curve. If the bricks don't quite meet at the corners, purchase a few smaller bricks or just fudge it a bit! It is not a load bearing wall, so you can't cause too much damage. Planting that falls over the edges will cover a lot of imperfections.
- Step 3:
- The Ezi wall system does not need any mortar or concrete. Line up the second and subsequent rows with the 'lip' acting to anchor each to the bricks below. Use a stretcher bond pattern. You need to use a small broom to clean any debris from the row you are building on.
- Pour in some scoria or drainage gravel near the wall all around to help with drainage.
- Fill the garden bed with premium garden mix, which is delivered in bulk. Estimate how much you will need. I was building a few beds, so a bit over was ok.
- Add some bags of compost and manure and dig into the soil with a fork. You will need to slightly overfill, as the soil will drop over time.
- Put a ring of polypipe down if you are going to reticulate.
- Step 4:
- Time to plant! I used 2 heliconias at the back that would grow to 3m to screen out the house behind and provide flowers and shade. Then a couple of shell gingers.
- The sunniest part has orange heliconias that can tolerate the sun and add colour.
- The front section has a small tree fern sheltering 2 garden fairies, a few cordylines for colour and 3 different colours of double impatiens.
- Mulch everything well and complete reticulation if required.
