I purchased a Holman wall-mounted hose reel from Bunnings and have completed the assembly. I intend to wind a 20 m recycled-water hose onto the reel.
I noticed that the supplied screws are relatively small (5 mm in diameter), and the wall plugs/inserts are approximately 7.5 mm in diameter. I am concerned about whether they can safely support the load, particularly when the hose is fully wound onto the reel.
Recently, I installed a Holman 20 m retractable hose reel at another location, using a 12 mm drill bit and larger wall plugs/inserts to accommodate the heavier load.
As the hose dimensions are similar, I am wondering whether the smaller screws and inserts supplied with this wall-mounted reel will be strong enough to withstand the load and the repeated force applied when turning the hand wheel. I am concerned that the screws may gradually loosen or pull out over time.
Could you please advise whether the supplied fixings are suitable for this application, or whether you would recommend using larger screws and wall plugs/inserts?
If I use larger screws, the screw heads may not fit properly into the existing countersunk recesses.
This could prevent the steel pipe from sitting correctly in place.
Could you please advise on a suitable solution that would provide sufficient strength without affecting the fit of the steel pipe?
Thank you for your If I use larger screws, the screw heads may not fit properly into the existing countersunk recesses. This could prevent the steel pipe from sitting correctly in place. Could you please advise on a suitable solution that would provide sufficient strength without affecting the fit of the steel pipe?
Thank you
