Black part of window latch part is broken.
It will not open the window.
The black part top and bottom should sit flat into where key is not popped out.
What is easiest way to fix.
Thanks
Welcome to the Bunnings Workshop community @Mit. It's wonderful to have you with us and many thanks for your lock question.
Unfortunately, if the locking mechanism itself has broken, it's unlikely to be repairable, and replacing the lock would be the best option.
It appears to be a proprietary locking system, so you'd first need to identify the window manufacturer to see whether a replacement mechanism is available.
If you can't source an identical replacement, you could consider an alternative, such as one of our push-button window locks. You'd need to ensure the replacement is compatible with your window frame and can be installed securely.
If you can identify the manufacturer or find any markings on the existing lock, we might be able to help you track down a suitable replacement.
Hi Mitchell,
The window could like the picture above.
I tried to push back the black part however it did not work.
So ended up the black part came off.
When the black part is off window still has the key section there but unable to open the window.
Tried putting the black part back on it was hard to and could not work out how.
Is there anyway the black part can be put back on?
Sorry I mean the window could open when it was looking the like picture above when it appears disconnected,
However black part is off now.
Anyway can put black part back on
Hi @Mit,
Unfortunately, this appears to be a proprietary locking system that we don't stock, so I'm not familiar with how the mechanism operates or whether the black component can be reattached.
I'd recommend identifying the window manufacturer and contacting them for advice on repairing the mechanism or sourcing a replacement.
How do I identify the window manufacturer?
How do I identify who the man
In the absence of any branding, that would be difficult @Mit. Check for any stamps or codes that could be on the lock mechanism. If there were a code, that might be something that would lead to a manufacturer.
Supplier is A&L Windows
It's good to see that you could identify the manufacturer.
Unfortunately, as they are not a business that we deal with, at this point the best thing you can do is contact them directly for assistance.
Hopefully they will be able to help identify the specific part and assist with sourcing a replacement.
