Hi Everyone,
I was just wanting a guide on how I fix these holes in my basement door.
Step by Step and what I need to buy
Thanks
Hello @Anna.M
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your cement door trim.
I propose using https://www.bunnings.com.au/dingo-10kg-mortar-mix_p0760516 along with https://www.bunnings.com.au/craftright-150mm-pointing-trowel_p0924471 . The basic steps are to mix the mortar in a medium sized bucket. Make sure to follow the instructions in regard to how much water to use. You are technically after the consistency of peanut butter. Too much water and the mix will turn into slurry which can't be used. Should you accidentally add too much water add more mortar to thicken the mix.
Here is a handy guide - How To Mix Mortar
My best advice is to clean the broken sections and remove any loose dirt and debris that may be in the gaps. Apply the mortar patch with your pointing trowel, make sure to shape it in the same angle as the others on the door. Allow the mortar to fully cure before painting the surface. I suggest using https://www.bunnings.com.au/dulux-1l-1step-prep-primer-sealer-undercoat_p1370232 and your choice of interior topcoat. An example would be the https://www.bunnings.com.au/dulux-interior-paint-wash-wear-matt-vivid-white-1l_p0638914 tinted to your preference.
