This is in my basement- all other walls in the room are covered up apart from this part around the door. I would also need the ceiling hole covered. Ideally would like access to the plug too if possible.
Thanks
Hello @Anna.M
Welcome to the Bunnings Workshop community. it's sensational to have you join us, and thanks for sharing your question about your wall cover.
I propose having a timber stud frame built in front of the brick wall and then covering it with standard plasterboard to tidy up the look. But before covering the wall, I suggest engaging the services of an electrician and have the existing power point transferred to the front of the new stud wall. This would also be a good opportunity to ask the electrician to install an extra power point on the other side of the wall so that you can access it from there and not have to run an extension cord through the door. In regard to the ceiling gap, that can easily be covered with a plasterboard ceiling panel cut to the size needed. Your handyperson or builder should have no issues covering that up.
Let me call on our experienced members @Dave-1, @Nailbag, @DIY4Knuckleheds and @mikebarker for their recommendations.
Hi @Anna.M
Any plasterer can fix plasterboard directly to the brickwork providing its flat. So you may need to do some prep work. The black cable would need to be relocated. Otherwise you wonโt need a stud wall but you would need timber battens fixed to the bricks to create a cavity. An electrician would be needed to disconnect the PowerPoint and relocate the ceiling light switch to the wall. A decent handyman could actually do all the with other than the electrics.
Nailbag
G'day Anna.M, if this was me l'd batten the wall out to cover electricals and then fit plasterboard to those battens. You would also need to add some timber to the edge of the door jamb so that it finishes flush to the plasterboard. Good luck ๐
Good Evening @Anna.M
I would go for framing up around the area and then plastering as @EricL has suggested. I would definently get a sparking out to extend the power point and then come back and fix it to the plaster once you have it up.
Garage lining for stud walls stage 1
Garage lining for stud walls stage 2 (Cornice and skirting boards)
Just to show how easy it is to do, it felt daunting at first but if you break it down to smaller stages it works a lot easier. Frame out, Sparky out, plaster, sparky back, trimmand then paint :)
