Can I laminate this benchtop to cover the watar marks? If so, what material would be best suited for this purpose?
Hello @Docnhabib
The laminate cover you are looking for will need to be specially ordered at the trade desk. It's called the Laminex laminate panel, they come in large panels from 1800mm to 2400mm. The timber table will need to be totally sanded down and made perfectly level. The timber gaps will need to be filled in, and any imperfections repaired before the laminate is placed on top. It is possible to do a D.I.Y installation of this, but I would recommend getting a professional to do this as a high level of experience and attention to detail is necessary to make sure that the laminate is installed square to the table surface.
I would also recommend thinking about replacing the entire benchtop with a Kaboodle benchtop. It comes in stone, timber and marble laminate finishes. It can be custom cut and sized to your needs. I suggest visiting your local store and speaking to the in-store kitchen specialist. They will be able to quote you the price of a Kaboodle laminate benchtop.
Here is a handy guide: Fixing benchtops to your cabinets
