Is there a template or guide available for watering different types of plants (e.g. Banana, Guava, Mango etc)? Each plant has different water requirements, both in terms of quantity and watering frequency, depending on its growth stage and feeding needs.
I am also looking for a water flow meter that can be connected to a retractable recycled-water hose, so I can measure and track the amount of water being applied to each plant, based on above standard / guide.
Secondly, I would appreciate your advice on soil nutrient monitoring. Is there a meter or sensor that can be inserted into the soil to measure key parameters such as nitrogen (N), phosphorus (P), potassium (K), pH, moisture, and other essential nutrients? Ideally, I am looking for a solution that can indicate when compost, fertiliser, or other nutrients need to be topped up.
Thank you.
