When we purchased our home, this corner of the backyard was wasted space. The existing retaining wall was so close to the shed roof you couldn't even stand upright! With limited machinery access, I removed the retaining wall and excavated the entire area by hand, determined to unlock its potential. What followed was a complete DIY transformation featuring custom curved concrete seating, a timber pergola, decorative stone and festoon lighting. What was once an unusable corner has become a welcoming firepit retreat creating the perfect space for our family to relax, entertain and make lasting memories together.
Materials Used – DIY Backyard Firepit and Pergola Area
The majority of materials used I purchased from Bunnings.
- Brighton Masonry 390 x 190 x 190mm Full Besser Blocks – Used to construct the curved masonry seating surrounding the firepit.
- Davco 20kg Off White Render – Applied to the Besser blocks to create a smooth, modern finish on the curved seating.
- Bastion 20kg Concrete Mix – Used for the concrete foundations and construction of the seating area.
- 88 x 88mm 2.4m H3 LOSP Treated Primed Laminated Pine Posts – Used as the vertical support posts for the timber pergola.
- 140 x 35mm Outdoor Framing H3 Treated Pine – 3.6m – Used to construct the horizontal framing and overhead structure of the pergola.
- Jack 1800 x 1000 x 200 x 7mm Reinforcing Mesh Sheet – Used to reinforce the concrete construction for additional strength and durability.
- RELN Stretch Ag-Pipe 100mm x 8m Slotted and Socked – Installed behind the retaining wall to improve drainage and help prevent water buildup.
- ANL 60L Eucalyptus Mulch – Used in the surrounding garden beds to create a natural finish and help retain moisture.
- Lytworx 50 Warm White Connectable Aspen Festoon Lights – Installed around the pergola to create a warm and inviting atmosphere for evening entertaining.
- Philips Hue Bridge Smart Accessory – Incorporated into our smart home setup to automate compatible outdoor lighting and integrate it with Amazon Alexa for convenient voice control.
- Native Australian Plants – Newcastle Wildflower Nursery – Purchased from a local native plant nursery to landscape the surrounding garden beds, introduce greenery and complement the natural appearance of the firepit area.
- Crushed Cowra White 3–8mm Pebble – Oz Landscape Supplies – Used as decorative ground cover beneath and around the firepit, creating a clean, contrasting finish against the rendered seating and timber pergola.
- Icon Plastics 3m PVC Gutter – Installed to help collect and direct rainwater away from the firepit area.
- Jack 180mm x 8m Super Gutter Guard – Installed to prevent leaves and debris from accumulating in the guttering, reducing maintenance and helping maintain effective drainage
- Jack 25–40mm Plastic Reinforcing Bar Chair – 20 Pack – Used to support and correctly position the reinforcing mesh within the concrete, ensuring the reinforcement remained elevated during pouring to improve the strength and durability of the concrete structure.
Tools Used – DIY Backyard Firepit and Pergola Area
- Saxon Round Mouth Long Fibreglass Handle Shovel – Used to manually excavate the entire area, removing soil and preparing the ground for construction. With limited machinery access, this was one of the most heavily used tools throughout the project.
- Ozito 120L 550W Cement Mixer – Used to mix concrete for the foundations and masonry construction, ensuring a consistent mix throughout the project.
- Trojan 2kg Mattock with Pickhead Fibreglass Handle – Essential for breaking up compacted soil and digging through difficult ground during the extensive hand excavation.
- Craftright 250mm Brick Trowel – Used for laying the Besser blocks and applying mortar during construction of the curved masonry seating.
- Kango 355mm Pointed Concrete Trowel – Used to spread, shape and smooth the concrete during construction, helping achieve a neat and consistent finish.
- Ryobi 18V ONE+ HP Brushless 4-Piece 4Ah Kit – Used throughout the project for cutting, drilling, fastening and assembling the timber pergola and other components.
- Sherlock 100L Steel Tray Wide Wheel Wheelbarrow – Used extensively throughout the project to transport excavated soil, concrete, gravel and other building materials. Particularly important during the manual excavation, as machinery couldn't access the area, meaning all excavated material had to be removed by hand.
Step 1: Planning the transformation
With a young family, we wanted to make better use of our backyard and create a space where we could spend quality time together, entertain friends and enjoy being outdoors. I started planning how we could transform this awkward corner into a welcoming firepit area that was both practical and visually appealing. The design centred around curved built-in seating, a firepit, timber pergola and native gardens. I also needed to carefully consider the existing ground levels, drainage and limited access, ensuring the space would be functional and something our family could enjoy for years to come.
- Step 2:
Step 2: Removing the retaining wall and excavating by hand
This was easily one of the most physically demanding parts of the project. With extremely limited access for machinery, the entire area had to be excavated by hand using a shovel, mattock and wheelbarrow. I removed the existing retaining wall and dug out the ground to lower the overall level, creating enough headroom and space for the new entertaining area. It was hard work, but seeing the potential of the space kept me motivated.
- Step 3:
Step 3: Preparing the foundations and drainage
Once the excavation was complete, I prepared the ground for the new layout. Drainage was an important consideration, particularly with the surrounding retaining walls. I installed slotted and socked ag pipe to help manage water behind the retaining wall. I also prepared the concrete foundations, using reinforcing mesh supported by plastic bar chairs to provide additional strength.
- Step 4:
Step 4: Constructing the curved seating
One of the main features I wanted was permanent, built-in seating that would encourage family and friends to gather around the firepit. Before committing to the design, I laid out the Brighton Masonry Besser blocks to experiment with different positions and see whether the curved seating I had envisioned would actually work. This allowed me to visualise the shape, adjust the layout and ensure there was enough room around the firepit. Once I was happy with the design, I began laying the blocks to create the curved seating, turning an idea into one of the standout features of the project.
- Step 5:
Step 5: Concreting and rendering the seating
With the blockwork completed, I used the cement mixer to prepare the concrete and finished the seating structure. I then applied Davco Off White Render to the masonry, transforming the exposed blocks into a smooth, modern feature. The curved rendered seating became one of the standout elements of the entire project.
- Step 6:
Step 6: Building the timber pergola
With the curved seating completed, it was time to remove the remaining walls and corrugated iron roof sheets, which I had deliberately left in place throughout construction to provide some protection from the rain. Removing these completely opened up the area and allowed the space to take on its new look. Using H3 treated pine posts and 140 x 35mm treated pine framing, I constructed the timber pergola to add warmth, character and an attractive overhead feature. The pergola also provided the perfect framework for hanging festoon lighting, helping create a welcoming outdoor entertaining space for family and friends.
- Step 7:
Step 7: Installing guttering and gutter guard
I installed PVC guttering and gutter guard to help manage rainwater and reduce the buildup of leaves and debris. Given the surrounding structures and landscaping, I wanted to ensure the finished area was practical and easy to maintain, not just visually appealing.
- Step 8:
Step 8: Laying the decorative stone and installing the firepit
To create a clean, low-maintenance surface, I used Crushed Cowra White 3–8mm decorative pebbles sourced from Oz Landscape Supplies. The light-coloured stone contrasts beautifully with the rendered seating and timber pergola. With the ground covering completed, the firepit became the centrepiece of the entertaining area.
- Step 9:
Step 9: Landscaping with Australian native plants
I wanted the finished area to feel connected to the surrounding garden, so I purchased Australian native plants from Newcastle Wildflower Nursery. I planted these around the firepit area and finished the garden beds with eucalyptus mulch from Bunnings. The native landscaping adds greenery, texture and a softer, natural appearance to the space.
- Step 10:
Step 10: Installing lighting and enjoying the finished transformation
The finishing touch was installing warm white festoon lighting around the pergola to create a welcoming atmosphere in the evenings. I also incorporated Philips Hue smart home technology to automate compatible lighting and integrate it with our Amazon Alexa system.
What started as a completely unusable corner of our backyard has become one of our favourite places to spend time together. Seeing the transformation after all the digging, construction and landscaping has made the hard work worthwhile. We've created a space where our family can relax, entertain friends and enjoy making memories around the firepit for years to come.
