Hi everyone,
I've recently leased a small commercial shop and am planning a quick, budget-friendly floor refresh using white water-based concrete floor paint.
The existing floor is bare concrete with a relatively smooth surface. The shop won't have any vehicle traffic, just moderate to slightly higher pedestrian foot traffic.
I came across the Rust-Oleum Concrete & Garage Recoat Primer, which advertises "No Sanding, No Grinding."
However, I noticed that the product is primarily designed for sealed or previously coated concrete.
My questions are:
- Can this primer also be applied directly to bare, previously untreated concrete?
- Would it allow me to skip acid etching or mechanical grinding before applying water-based concrete floor paint?
- If not, is there another primer or painting system available at Bunnings that would allow me to paint bare concrete without acid etching or grinding?
I'm mainly looking for a simple, affordable solution rather than a heavy-duty industrial floor finish. Since the shop has no floor drain, I'd particularly like to avoid acid washing and the associated wastewater cleanup.
Any advice or product recommendations would be greatly appreciated!
Thanks in advance!
