I need to remove a cabinet a wash basin with a tap connection. Is there a way cap the water line for 2-3 days so that I don't need to turn off the mains?
I have a attached a photo of the tap connection inside the cabinet.
Hello @akoong
Thank you for sharing your question about your water line. Please note that plumbing work needs to be completed by a licensed professional for safety and compliance. Any changes that involve moving or reconfiguring pipework (which includes capping a water outlet) would be considered regulated plumbing work and would need to be carried out by a licensed plumber.
One alternative I would like to propose is instead of asking the plumber to cap the outlet, I suggest asking your plumber to install a https://www.bunnings.com.au/brasshards-loose-nut-mini-cistern-tap-15mm-chrome-lead-free_p0571954 on both the hot and cold outlet. This will give you the option of stopping the water in case of a leak or an emergency.
Hi @akoong,
Out of curiosity, have you checked what this hose connects to?
Given you have a hose connected to another hose, I wonder if the hose that sits behind the basin might already run to a cistern tap like the one Eric mentioned.
If that was the case, you could simply turn it off which would mean you can avoid contacting a plumber for assistance.
Hi Eric & Jacob,
Thanks for your response. I have managed to cap the water line temporarily using a 15mm brass threaded cap that I bought from Bunnings. I can now remove the cabinet to oil the deck.
Regards Alan
Thank you very much for the update. It's good to hear that you've capped your water line.
