to create a cactus and succulent garden on the western side of our 10,000 square mt block in Southern NSW.
plants from the Bunnings nursery, bags of Cactus potting mix, rapid set concrete, bags of compost, treated pine sleepers, pesticides, fertiliser, planter boxes for the wall, screws and bolts
tools used and from Bunnings include, Makita battery chainsaw, Makita angle grinder, Makita drill Makita line trimmer, Full Bore jack hammer, safety gear to handle Cacti, plus other assorted hand tools, such as shovels, levelers Bench seat from Bunnings and the Gabion colombs at the entrance, which became a great place to put our Magpies.
our aim was to clean up an eyesore that was getting worse every day. it was a snake pit and heavy rain would make it impossible to do anything with it. We firstly had to clean up the site removing the rock, and leveling. Drainage was the biggest problem as water flows from the top of our block straight through the proposed garden area. A small Kioti tractor certainly helped with moving rocks up to 500kg
- Step 2:
Our block has a heavy clay content, so drainage was paramount, we made 8 mounds approx 4mts in diameter and 30cm in height with a mix of 10mm agrigate, course sand compost and used the smaller rocks as a border around each mound, to hold the mix in place and to form a path which was made from 20mm blue metal stone. we placed some of the large rock in each mound as features before planting. after planting we put a layer of gravel on each mound
- Step 3:
we purchased as many plants as we could from Bunnings nursery (with the assistance from Phil the resident Bunnings Nursery team member and a wealth of knowledge) we had friends that had some cacti so we raided their gardens for cuttings and any excess plants.
- Step 4:
to give a back drop to the garden, we used 400 x 2nd hand posts from a winery in the MIA. the posts were drilled with 2 holes and fed onto reo-bar with steel posts concreted in for support. each post was hand positioned, to follow the conture and the roots of the gum trees. this wall also became part of our water diversion to stop any water flowing through the garden, and to provide a visual boundary of the garden on the western side and 150mm steel edging around the garden on the eastern side
- Step 5:
once the 8 mounds were completed and the majority of the heavy planting done, we then filled the gaps between the mounds with blue metal to form a walk way through the garden. as there was a 150mm steel edging on the eastern side of the garden we needed a safe entrance, this was done with a steel frame to hold the treated pine ramp over the steel edging.
- Step 6:
We started this project on the 5th May 2026 and this week we have the first of our flowers from some of the cacti. everything has been constructed by myself (73yo) and my wife Debbie (68yo) working on it every day and weekend, (as well as running our business) The project has given us both enormous satisfaction and also keeps us active and motivated. Our next project will be to finish replacing the lawn around the outside of the garden and then a rain forest garden at the bottom of our block. Wayne Lennon
