Hi Is installing below security system in a two storey home complex? Can it be a DIY project?Swann AdvancedX Wired NVR Security System 8 Channel with 8 Dome Cameras - Bunnings Australia Thanks
Hello @nagumuthu
For an 8-camera wired security system on a two-storey home, I would recommend getting a professional security camera installer, particularly if the cameras need to be mounted high up or the cables need to run through walls, ceilings and between floors.
Although installing a wired CCTV system yourself is possible in some circumstances, there are several things worth considering. Running eight separate cables back to the Network Video Recorder (NVR) can be challenging, especially in a two-storey home where access to wall cavities and roof spaces may be limited. You'll also need to consider camera positioning, cable protection, weatherproofing and suitable recording equipment.
Working at heights is another important consideration. Installing cameras around the upper level may require scaffolding or an elevated work platform rather than an ordinary ladder.
In Australia, fixed security camera cabling may be subject to telecommunications cabling regulations. Plus, fixed data cabling generally needs to be installed by an appropriately registered cabler. Any new 240V electrical work must be completed by a licensed electrician.
My suggestion would be to have a professional install the cameras and run the cables, while you handle the set-up tasks, such as connecting the NVR to your monitor, configuring the mobile app and adjusting recording settings.
This approach gives you the benefit of a professionally installed system while still allowing you to manage its everyday operation.
Let me call on our experienced members @CSParnell, @Dave-1, @Nailbag and @DIY4Knuckleheds.
Good Evening @nagumuthu
@EricL's reply is a good response that covers most of my concerns as well. Its a pricy system to install for a first time is my first thought. Second and primary support was this line in the description "Benefit from comprehensive pre-event recording and free local storage for up to 6 months on the 1TB HDD." One of my biggest frustrations with security systems is having access to my own recordings and not have to pay a third party app to have access. I would have the access time clarified before entering into any purchase.
So far Myself and my workmates have only found a few cameras that allow local recording to somewhere and not have to pay for it. Its a topic that is discussed at the round table of coffee frequently.
