The black paint is failing on my outdoor, built in BBQ cover. What can I use for a touch up?
Thanks David
Hi @David39,
I'd recommend using White Knight 300g Hi Temp Pot Belly Black Spray Paint to freshen up the exterior of your barbecue. It's a self-priming, heat-resistant paint designed for metal surfaces exposed to high temperatures, including barbecue surrounds.
Preparation will be the key to getting a good result. I'd suggest starting by sanding back any peeling or flaking paint, along with any surface rust, until you have a sound surface. You can then give the barbecue a thorough clean with warm soapy water and a degreaser to remove any grease and grime. Rinse it down and allow it to dry completely before painting.
Next, use painter's tape and masking materials to cover any areas you don't want painted, such as handles, knobs, vents and other fittings. You can then apply the Pot Belly Black in light, even coats, following the manufacturer's instructions for drying times and heat curing.
Just be aware that this paint is intended for external surfaces only. It shouldn't be applied to cooking plates, grills, burners or any surfaces that come into contact with food or direct flames.
You might also like to have a look at @moniquecole1990's Barbecue makeover using spray paint, which is a great example of what can be achieved with the same product.
