I have followed the instructions given on the instruction sheet and in a previous workshop post. But the seat is still loose. Can anyone explain why??
Hi @Ewans,
Welcome to the Bunnings Workshop community. It is wonderful to have you with us.
Would you be able to upload a few photos showing the toilet seat, the mounting hardware and what you've managed to install so far? This would help us identify where you're running into trouble and offer some more specific advice.
Can you also confirm whether you're using top-fixing or bottom-fixing hardware? A link to the specific toilet seat you've purchased would also help. Top-fixing seats are secured from above, usually using expanding fixings that grip inside the mounting holes, whereas bottom-fixing seats use bolts that pass through the toilet pan and are secured with nuts underneath.
If you're using top-fixing hardware, it's worth checking that the expanding fixings are inserted correctly and that they're gripping securely when tightened. If you're using bottom-fixing hardware, make sure the washers and nuts are positioned correctly and that the bolts aren't spinning as you tighten them.
If the issue is with attaching the seat itself, check that the mounting posts are correctly aligned with the hinges. Some soft-close toilet seats also have a quick-release mechanism that needs to engage properly before the seat will lock into place.
Once we can see the hardware you're working with and understand which part of the installation is causing trouble, we should be able to offer some more specific guidance.
Dear Jacob, thanks for replying.
Here are some shots. Hope these give you enough to advise me!
Michael E.,
Jacob, please reply before 1 pm AEST if possible; I need help with installing this and my helper leaves at 1:30
Hi Michael (@Ewans),
Tough to tell exactly what is wrong but I suspect it could be because the locking nuts were fully tightened before the toilet seat was sat in place and adjusted. I'd suggest loosening the nuts, adjusting the plates so they have a firm connection with the toilet seat, then tightening the nuts down tightly.
Give this a try and let me know how you go. I can certainly assist further if required.
I've tried that, but will try again!
Let us know how you go @Ewans.
Happy to help further if required.
I'll try again tomorrow when I have a friend with stronger hands than mine to loosen and tighten the bolts. Will get in touch if I have problems then.
