Laid our brick path and spent lots of time making sure the levels & falls were OK, but when I used the hose against the weatherboards some of the water shedding off would drip behind the bricks and go under the house.
Also at the edge of the channel drain it's a little flat and falls away under house slightly (rather than directly into drain).
To fix it could I run a bead of flexible sealant against weatherboard and bricks where possible and then where gap is larger simply pack with grout / mortar?
There is building wrap/plastic between the wall frame and the weatherboards so any grout/mortar would be against the wrap rather than the timber.
I realise you're supposed to have more of a gap probably but this is the best we could do.
Im not sure how I could have given more of a gap cause we have the fixed levels of the driveway concrete and the porch.
