Hello, our timber floorboard needs sanding but this is not something we can do for now and in the nearest future . In the meantime, I want to “spot-fix” several small areas. I’ve looked at other posts, but I haven’t seen advice on the different types of damage I’d like to fix. We moved here in the past year so don’t have details of the varnish, etc, used.
The uploaded photos show what I’m dealing with. I’ve numbered them so it’s easier to refer to them.
Thanks in advance for your precious advice.
Hi @DIYLili,
Unfortunately, most of what you've pictured is the type of wear and damage that accumulates over the years before timber floors need to be sanded and recoated. While there are ways to improve its appearance temporarily, much of this damage isn't something you can simply spot-fix.
The main issue with attempting to repair individual scratches and worn areas is matching the existing coating. As you don't know what product was originally used, applying a new coating to isolated areas could leave noticeable patches with a different colour or sheen. These patches could end up looking just as bad, if not worse, than the original scratches.
One option worth considering is Feast Watson Floor Polish. It's a water-based polish designed to add shine and protection to previously coated timber floors. Products like this can help diminish the appearance of light surface scratches and restore some uniformity to the finish. However, their effectiveness on deeper scratches and areas where the coating has worn through will be limited. I'd recommend testing it in a small, inconspicuous area first to see whether you're happy with the results.
For deeper scratches that have penetrated the coating and exposed the timber, a polish won't restore the original colour or protection. Similarly, any gouges, dents or damaged timber fibres, would generally require filling or sanding before refinishing.
You could potentially use a colour-matched timber filler to address some of the gaps between boards. However, this is usually best done in conjunction with sanding and recoating the floor, as the filler can be difficult to blend into the existing finish. It's also important to distinguish between actual damage and the natural gaps that occur as timber expands and contracts with changes in temperature and humidity. Filling these movement gaps with a rigid filler can lead to cracking or the filler breaking away.
Given that you're not planning to sand and recoat the floors in the near future, I'd suggest concentrating on improving their overall appearance rather than attempting individual repairs. A suitable floor polish might help disguise some of the lighter wear, but I'd avoid applying new varnish or attempting extensive filling until you're ready to refinish the entire floor.
Another option worth considering is recoating the entire floor with a product such as Cabot's CFP Floor. Depending on the condition of the existing coating and the results of an adhesion test, you may be able to apply a new coating without sanding the floor back to bare timber. However, you'll need to follow the manufacturer's preparation requirements.
The advantage of recoating the entire floor rather than individual sections is that you'll achieve a much more consistent finish. A fresh coating could help disguise many of the lighter scuffs and surface scratches while restoring the overall appearance of the floor.
Keep in mind that deeper scratches, exposed timber and physical damage will still be visible, so this won't achieve quite the same result as a complete sand and refinish. However, it could be a worthwhile compromise until you're ready to have the floors professionally restored.
Here's a helpful step-by-step guide: How to seal a timber floor.
Thanks a lot, Mitchell. As always, you say it like it is and you’re super helpful in finding solution where possible but also being honest when things are not possible! I’ll explore the things you mentioned in more details.
As a side question, our outdoor deck has one area where 20cm of the board it damages, like it was pulled and some of wood is like spiking out. I can make another post if you want to share a photo. What would be a solution for this?
You're most welcome @DIYLili, and I really appreciate your kind words.
It would probably be best to start a new post about the damaged decking so we can look at that issue separately. Please include a few photos of the damaged area, and we'll be happy to help you work out the best way to repair it!
