I am looking for ways to get rid of the rust on the metal carport frame and repaint after getting g rid of it. If there a product can use?
Hi @TisungeChinseu,
Looking at your image, I'm concerned that the corrosion has progressed well beyond surface rust. There appear to be sections where the rust has eaten through the metal, resulting in a loss of material from the structural beams. At this stage, it's no longer simply a matter of removing the rust and repainting, as the structural integrity of the carport could be compromised.
I'd strongly recommend having a suitably qualified structural professional assess the frame before attempting any repairs. We're only seeing the underside of the beams, and if the concealed sections are similarly corroded or worse, sections of the structure may need to be dismantled and replaced.
Unfortunately, rust converters, primers and protective paints won't restore the strength of metal that's already been eaten away. Although these products are excellent for treating surface rust, I wouldn't recommend relying on them in this situation.
I'd also suggest avoiding standing beneath or placing additional loads on the affected structure until it's been assessed.
Ok, thank you so much. I really appreciate the feedback.
