I've got a pergola structure built in my garden. I would like to add on a roof onto it. I have attached images of the pergola structure. The dimensions of the pergola is also included. The existing pergola is basically flat. So I need to add a roof with a minimum slope of 5 deg. I am planning on cutting lengths of timber and propping the roof up at an angle. First thing I need help with is to come up with the bill of materials for this.
Secondly, I need help deciding what roof material. I would like some amount of sunlight to be able to come through the roof without it getting too hot during summer. I have heard I should stay away from polycarbonate roofing as over time they will start to create creaking noises. Perhaps I should do a combination of metal and polycarb? Thirdly, I would like advice on is the direction of slope. Below are the options I am considering: a) Slope away from the house. Need to add the most amount of guttering back to my down pipe. b) Slope the roof towards the house. This minimizes the amount of guttering I need to add. c) Slope towards the house but mount the roof higher so that it drains directly into the existing gutter on the side of the house. This requires no new gutters but means I need to mount the roof quite a bit higher than the existing pergola.
Hello @shaon12sen
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your pergola.
It's great to hear that you have decided to add a roofing cover to your pergola. However, adding a roof to an existing pergola can change how the pergola framework handles wind loads and additional weight. A roofed structure like this will often require council approval, so I suggest checking with your local council first to confirm what approvals are necessary before proceeding. I also recommend having a builder or suitably qualified professional confirm that the existing structure can support the proposed roofing system.
In regard to your second query on materials, it will depend on what the builder or draftsperson/engineer will recommend. When making structural additions to an existing home, it's important to consider how the proposed changes might affect the original structure. I would recommend speaking with a qualified draftsperson or structural engineer who can assess your plans and determine what's required. There are specific structural calculations and load-bearing considerations involved that are best left to qualified professionals. This will help ensure your proposed additions are safe, properly supported and meet the relevant building requirements.
As to the slope, I propose having it slope away from the house. I believe this would be the safest option as water is flowing away from the house instead of towards it.
I also suggest looking at these discussions - How to install battens and create a slope for polycarbonate roofing on a pergola? by @aallabadi and How to build a pergola with polycarbonate roof? by @jeffrey84.
