Trying to temporarily remove the sliding doors so I can throughly clean them individually but not sure where to locate the right tools to do this (screw driver, screws because the one in the photo looks damaged). The sliding blocker seems to be missing as well because the owner used pieces of carboard to keep it in place which is not safe. Could you please help me figure out please?
Welcome to the Bunnings Workshop community @BWHLPAJTBTIOP1234567. It's wonderful to have you join us.
Most sliding doors can be removed by lifting them up into the top track and then swinging the bottom of the door out. However, some have adjustable rollers or anti-lift blocks that need to be released first.
I'd recommend cleaning the sliding doors while they're still in place, rather than attempting to remove them. Removing sliding doors can be quite awkward and difficult, particularly if you're unfamiliar with how their rollers and tracks operate.
Given that cardboard has been used as a makeshift solution to hold the doors in position, I'd be concerned that there may already be an issue with the hardware. In this case, I'd be inclined to enlist the services of a professional to assess the doors, safely remove them if necessary and replace any damaged or missing components.
This would also be a good opportunity to have the doors adjusted so they operate correctly and safely.
Please also be aware that glass doors can shatter unexpectedly if their edges or corners are knocked against hard surfaces. This presents a significant injury risk, so appropriate PPE, including safety glasses, cut-resistant gloves, a long-sleeved shirt, trousers and enclosed footwear, is essential when handling them. Given the risks involved, professional assistance would be the safest option.
