Hi all,
I'm after some advice on a leaking metal box gutter, and whether butyl flashing tape would work as a DIY fix.
The setup
- Single-storey house, metal roof of about 300 m², all draining into one box gutter
- Box gutter about 30m long and 370mm wide, behind a parapet
- 4 × 100x100 downpipes with plain round outlets (no sumps), feeding a charged line to a rainwater tank
- Roof sheets sit directly on the back edge of the gutter, about 75–80mm above the floor
- Poor fall: water pools about 10mm deep at one end
What's been done so far
- A roof plumber fitted 4 overflow chutes (200x50), then 3 more at 400x65, set lower so the tops line up
- A rainhead with a front spout and leaf guard on the side downpipe, to stop the tank line backing up into the gutter in heavy rain
- That's helped, but the plumber also found that the joints along the parapet side are just screwed, with no proper sealing
What I found
- The parapet lining (the vertical sheet on the parapet side) doesn't sit flush on the gutter floor. There's a gap along most of the length, and I can get my finger under it.
- In some spots it doesn't feel like the gutter's upstand behind the lining goes up very high, so I think water is getting behind the lining at a fairly low level.
- The vertical joints in the lining are screwed with no sealant inside the lap.
My plan and questions
As a stopgap, I was going to run neutral-cure roof and gutter silicone along the bottom edge of the lining where it meets the floor, and up the vertical joints and screw heads. My plumber will quote a proper fix later, probably a sealed angle flashing riveted along the corner.
- Would butyl flashing tape be better than silicone here? I'm thinking aluminium-faced, 100–150mm wide, run along the corner so it covers about 50mm of the floor and 50–100mm up the lining, plus over the vertical joints.
- How does butyl tape hold up in a box gutter where water sits on it for hours during rain, plus full sun?
- Is there a product or width people recommend? And is a primer needed on Zincalume?
- Any surface prep tips? I was planning to scrape, then clean with mineral turps and let it dry.
- Would sealing the bottom edge of the lining trap water behind it? For example, water coming down from the parapet capping.
- Any other thoughts or things I've missed?
Photos attached. Thanks in advance!
Disclaimer: edited with AI to help. I’ve also missed the time I could complain to builder so can’t go that route either
