Hi, I need to fit a new solid timber front door and plane the sides to size. What’s the best way to hold the door securely on its edge so I can safely use an electric planer? Thanks.
Hi @nila,
The easiest way to hold the door securely would be to use a pair of sturdy sawhorses with timber supports or clamps to keep it upright on its edge. Alternatively, you could construct a simple door-holding jig using timber offcuts, creating two supports that cradle the bottom of the door and prevent it from tipping sideways.
Our friends over at Tool Kit Depot also have these OX Pro Door Clamps, which are specifically designed to hold doors upright while you're working on their edges. They could be a convenient option if you'd prefer not to construct your own supports.
Whichever method you choose, ensure the door is securely supported and cannot tip or move while you're using the planer. If using clamps, position them clear of the planer's path and use protective timber blocks where necessary to prevent damage.
Before starting, mark your cutting line and check the manufacturer's specifications for how much material can be removed from the door. Take several shallow passes rather than trying to remove too much at once. Be particularly careful at the ends to avoid splintering the timber.
Remember to wear safety glasses, hearing protection and a suitable dust mask, and keep the power cord clear of the planer.
